... take it apart again so I can get the old one back in the box?
I wanted to hang on to the old hub for now but cannot get the power supply in the box. They come in two parts and, obviously, the old one has the two parts fastened together.
Solved! Go to Solution.
There is a button which when pressed will release the 3 prong part and enable you to then put in box
OK, I tried that but couldn't make it separate! As you think it ought to, I will pass the task to the larger and stronger household person. 😁
Thanks, will report back, but might be tomorrow now.
It actually took two of us to get it apart - one holding the button in with a pen while the other yanked the bits apart! Sorted though, so thanks for the help.
I've just been trying to do the same thing, but have come to the conclusion that it's impossible!
Or is there some clever trick that can be used?
As before, we succeeded but needed two pairs of hands!
@Sue036wrote:As before, we succeeded but needed two pairs of hands!
Thanks, I did eventually succeed using one pair of hands, but they don't make it easy!
