Message 1 of 4
BT Smart Hub
Ever since I have installed the BT Smart Hub, on 50% of my Start-ups I have to Restart because my Computer cannot find an internet connection. It should be finding the LAN cable which did work everytime with the previous Hub.
It can't be the connection because after Restarting, it finds the connection 100% of the time.
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub
Did you turn off smart setup?
Message 3 of 4
Re: BT Smart Hub
Hmmm, if I knew what you meant, I could answer.
What is smart setup?
