Message 411 of 433
Re: BT TV Box Pro - comments/questions
@ozsat yep 5.1
Amp just flipped dynamically.
Well done either bt or youview whoever fixed it.
Message 412 of 433
Rings of power
it doesn’t do Atmos I am afraid, nor on Apple TV 4K…
but I think it’s an Amazon issue…
Message 413 of 433
the accountant is 2.00 for me…
Message 414 of 433
@voles
WWhat box and software version are you on?
Tried rings and also jack Ryan via TV (uses Google TV) and atmos definitely working. Via bt box, it doesn't engage.
Bug in amazons app.
Message 415 of 433
My bt box is
sagerncom RTIW387
variant RTIW387.002.p
hardware version 0006
component s/w 4.1.6(7e09c6)
etc
Receiver Arcam AVR AV41
to go off on a tangent a bit… I can’t get atmos from Amazon music on my Apple TV 4K either…
Message 416 of 433
@voles
While its true the amazon app on BT Pro box doesn't output atmos, I think your setup has also a deeper issue. Hope you get that fixed.
Message 417 of 433
Deeper issue?
Message 418 of 433
I had to do a factory reset last night due to getting ‘content protection’ errors at every step - despite no attempt to watch a UHD channel.
after the reset ITVX replaced ITV HUB It seems bettter than the Apple TV version of the app.
Message 419 of 433
I've just found that ALL my 1am recordings on WWE live on BT Sport say 'Failed to Record'  -  yet most of my daytime recordings are correct and present.
Even last night's #465 football recorded complete.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 420 of 433
I don't know if it has been suggested previously or not but having enjoyed Virgin Media's TiVo for many months in the past and since switching the the BT Box Pro which shares many similar features I really do miss the fact that the BT box does not remember previous recording requests (I believe the SKY box can do that too). For example if I record say Springwatch for one season the box will remember that and automatically record all new season episodes unless requested not to. Can that feature be incorporated into a future software upgrade I wonder?
