Message 1 of 8
DNS Servers
Action Fraud (uk) are recommending that internet users make use of a free service from Quad9.net. Essentially it has a list of unsafe domain names and blocks access to those sites. It is offering this as an addition to any other malware system that the user might have (eg Norton offer a website name check for safety  https://safeweb.norton.com/ ) . Does anyone have any experience of or advice about Quad9.net ? Is it even feasible to access a DNS which is not the DNS used by your ISP ?
7 REPLIES 7
Message 2 of 8
Re: DNS Servers
You can use any DNS service you like, however, you can't change DNS servers on a BT Home Hub, you would need to change it on your PC/device http://winhelp2002.mvps.org/hosts.htm  is a better option to block unwanted sites on a PC.
Anonymous
Not applicable
Message 3 of 8
Re: DNS Servers
Googles DNS  servers are fast, safe & free to to use by the public. Likewise OpenDNS.
Message 4 of 8
Re: DNS Servers
It says in the websitethat some routers cannot be changed, so am I able to change my DNS to Quad9 or will my smart hub 6 reject it?  and I suppose another question is, is it worth it?
Message 5 of 8
Re: DNS Servers
You can't change DNS servers on any BT Hubs. You either need to have a third party router or change your device to have fixed DNS server addresses rather than using the hub ones.
Message 6 of 8
Re: DNS Servers
OK, I don't want to change anything on my smart hub, ( wouldn't know how to anyway) so presume I cannot change the settings on my laptop as it will not be accepted by the hub - is that right?
Message 7 of 8
Re: DNS Servers
The hub is not an issue here.  Just change the DNS servers in the properties section of the network card see example.
Some alternate DNS servers you can try.
OpenDNS
208.67.222.222
208.67.220.220
OpenDNS Filtered servers: DNS servers that block adult content(apparently)
208.67.220.123
208.67.222.123
OpenDNS IPV6
2620:0:ccc::2
2620:0:ccd::2
Google
8.8.8.8
8.8.4.4
Google IPv6
2001:4860:4860::8888
2001:4860:4860::8844
Verisign
64.6.64.6
64.6.65.6
Verisign IPv6
2620:74:1b::1:1
2620:74:1c::2:2
If you want more than that look here:
https://www.lifewire.com/free-and-public-dns-servers-2626062
Message 8 of 8
Re: DNS Servers
@icepuffin No, that's not right.  You CANNOT change DNS servers on hub, you NEED to change them on your laptop.
