Message 1 of 6
Devices connected through a cable to the Smart Hub drop Internet connection
Randomly throughout the day ALL wired devices lose connection to the interent. My wireless devices do not lose connection.
After waiting a few minutes the connection is re-established with no user intervention.
The BT Smart hub has been swapped and the problem continues.
It started happening when I upgraded to fibre and a new smart hub was sent, it has never happened before.
Any help would be greatly appreciated.
5 REPLIES 5
Message 2 of 6
Re: Devices connected through a cable to the Smart Hub drop Internet connection
can you post stats from your hub  advanced settings then technical log information
do you use powerline adapters?
Message 3 of 6
Yes I use ay powerline adapter.  2 devices go through the powerline adapter. My PC does NOT, the pc is connected directly into the router. My initial thought was the powerline adapter but I dismissed it as the pc also lost  at the same time.
Before the smart hub was installed, I used powerline adapters and did not have this issue. Admittedly, it was a different powerline adapter,  I changed it from a 1 device per adapter to one adapter for 3 devices. Hope that makes Sense!
Message 4 of 6
have you tried disconnecting the ethernet cable feeding powerline adapters and see if pc is any better - ie   eliminating the powerline adapters as causing a problem
Message 5 of 6
I have not tried that. I would have to sit in front of the pc though to see if it drops. Or is there a program a can install that would monitor this for me?
Message 6 of 6
A copy of the event log, the error occured again today at 16:20
16:46:32, 10 May.
wl1.1:Device <30:95:E3:09:5A:5F> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:46:29, 10 May.
wl1.1:A WiFi device <30:95:E3:09:5A:5F> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:46:01, 10 May.
wl1.1:Device <88:6B:6E:77:CF:A5> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:44:50, 10 May.
wl1.1:A WiFi device <88:6B:6E:77:CF:A5> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:44:49, 10 May.
16:44:49, 10 May.
16:34:09, 10 May.
wl0:Device <2C:0E:3D:E5:02:96> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
16:34:09, 10 May.
wl0:IGMP group 224.0.1.187 on interface wl0 ended by 192.168.1.178
16:30:53, 10 May.
wl0:IGMP join received for group 224.0.1.187 on interface wl0
16:30:53, 10 May.
wl0:IGMP group 224.0.1.187 on interface wl0 started by 192.168.1.178
16:30:53, 10 May.
wl0:IGMP group 224.0.1.187 on interface wl0 by 192.168.1.178 requested
16:26:02, 10 May.
wl1.1:Device <D0:87:E2:83:94:2E> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:25:02, 10 May.
wl1.1:A WiFi device <D0:87:E2:83:94:2E> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
16:21:15, 10 May.
eth4:[Device Connected] MAC Address:6c:62:6d:71:7c:cf Host Name: CompRoom-PC IP Address: 192.168.1.173, lease duration is 86400 seconds.
16:21:15, 10 May.
BR_LAN:The DHCP options that are offered by the device (id:1): DiscoverOptions: 53,61,12,60,55 | DiscoverOption55: 1,15,3,6,44,46,47,31,33,121,249,43 | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,15,3,6,44,46,47,31,33,121,249,43 | HostName: CompRoom-PC | VendorId: MSFT 5.0
16:21:15, 10 May.
:DHCP Confirmation of Request
16:21:10, 10 May.
eth4:An Ethernet port is now connected (5/100/FULL)
16:21:07, 10 May.
eth4:A device has been disconnected from an Ethernet port (5)
16:21:06, 10 May.
16:12:15, 10 May.
16:10:05, 10 May.
15:52:32, 10 May.
wl1.1:Device <2C:8A:72:8D:8B:15> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
15:50:53, 10 May.
15:50:45, 10 May.
wl1.1:A WiFi device <2C:8A:72:8D:8B:15> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
15:49:18, 10 May.
15:48:08, 10 May.
wl1.1:Device <6C:27:79:FC:A3:0C> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
15:48:05, 10 May.
wl1.1:A WiFi device <6C:27:79:FC:A3:0C> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
15:22:08, 10 May.
15:20:10, 10 May.
15:07:04, 10 May.
wl1.1:Device <A0:10:81:F9:CE:91> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
15:06:07, 10 May.
wl1.1:A WiFi device <A0:10:81:F9:CE:91> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
