Message 131 of 535
Re: Failed Recording
Even happening to new customers. I Should have stayed with ee tv 😟
Message 132 of 535
At least you can see from the evidence here that the problem is not indescriminate but affects most users. Now just need patience for the solution .....
Message 133 of 535
Failed recording
Why won't my box record some programmes anymore?
Message 134 of 535
Add another to the  list. Back from a few nights away and our box has many failed recordings, Emmerdale last night 4th June and tonight 5th June. Hubby also wanted to record the Isle of Man TT races and quite a few of those have also failed.
Message 135 of 535
Failed recordings
Came home from work yet again failed recordings today june the 6th 2018 first failure emmerdale itv 7.00pm second failure coronation st itv 7.30pm but when i turned recorder on before it was going to record 2nd corro it recorded the first one from 7.30 at 8.30 on itv 1 plus 1 plus it recorded the second corro at 8.30 because box was on. Plus it has put emmerdale to record in morning but it does not allways do this record it the next day.last failure was on channel 4 about week and half ago. I am getting my signal from the transmitter at sutton coldfield please sort this youview
Message 136 of 535
Good afternoon everyone - this update is a bit late as we have been working with YouView on testing and updates to our case studies.
Apologies for the ongoing issues, as you will guess we are continuing on a number of lines of investigation that are concentrating on the interaction between the transmission data from the broadcasters and how that feeds into the recording schedule that is locked in the set top box.
Additionally there's also a lot of information that we're looking at regarding changes to channel data caused by recent 700mhz work run by Digital UK that's freeing up space for 4G by moving channels further down the spectrum. It's instructive that many people here are telling us about issues around ITV and C4 recordings as these live in the same space (multiplex) which is different from where BBC channels are where we see less reports of failure.  The box needs to know where the channels are in order to start recording after waking up and we can see indications that the data isn't always getting to where it's needed, and if it's different from where it was when series-linked recording was originally set up could cause the signal to be missed - the box should be checking for changes but it's worth checking if you have a continuing failure on series episodes. If you do, try deleting and recreating those so that the box is forced to use the most up to date data from the network.
We have more testing underway over this weekend and I'll provide a further update early next week.
Thanks for your time and reports,
David
Message 137 of 535
One thing that I have noticed in the past couple of months and it's not on my Youview box but with our LG TV.  Quite often when I switch it on for the first time during the day (not time dependant) there is a message on screen stating the 'programme map' has changed click yes for retune or no.
Why the programme map should keep changing is a mystery as our house hasn't moved during the night.  Last week when I clicked yes the TV retuned and we ended up with BBC London instead of West Midlands (Sutton Coldfield transmitter).
Needless to say although the EPG had listed the revised data we couldn't receive BBC London and I had to retune the TV again whence all the correct channels populated the EPG this time.
We are nowhere near any transmitter that could possibly tune in to London and we have an almost brand new aerial in order that we can receive COM7 & 8 channels 55 & 56 - aerial is a Log Periodic.
Message 138 of 535
Do you live a fair distance from your main transmitter? I get the channel map thing all the time on my LG tv, and can pick up Oxford or Bristol depending on when I retune. Though if I end up with Oxford by accident it starts pixellating in the evening. Sometimes I can pick up Meridian, which is nowhere near where I live and has a terrible picture. Usually my tv picks up both, but then lets me choose which one to select as my main channel before doing the final save.
Message 139 of 535
Failed recordings
Dear all i have put about 3 posts on here about failed recordings on youview freeview 2110 bt box. Could someone please tell me on here when this is resolved.if not sorted soon im thinking of getting just a freeview plus box whoch sounds more reliable
Message 140 of 535
About 37 miles, though we also have the option of using a relay, but that is for the same transmitter, the only difference is the aerial alignment i.e. vertical instead of horizontal.
