Message 11 of 13
Re: Fibre 1 speeds
post your hub stats so can see what you are actually getting just now  a while back fibre 1 customers got a free upgrade to fibre 2 speeds and that may be where the confusion arises
Message 12 of 13
Re: Fibre 1 speeds
Have got to the bottom of it now, thanks for the replies and information.
Message 13 of 13
Re: Fibre 1 speeds
That's good. What was the outcome?
