Message 1 of 4
Fibre 900 - Asus ROG Rapture GT-AX11000 or Netgear NIGHTHAWK® TRI-BAND AX12 12-STREAM AX11000
Hi everyone, I’ve been having loads of problems with general performance since upgrading to Fibre 900 - they seem to have now solved the speed performance and getting 900 on a wired connection.
I would now try to put in place the best options to get the fastest Wi-fi speed.
I’ve been looking at the following:
- Netgear Nighthawk 12’Stream WiFi 6
My plan will be to get one of the above and then supplement with 1 or 2 other devices to create better coverage.
Any experience or tips with either devices would be great.
Mark
*Previously purchased Synology devices but bricked after a software update so now back on the smart hub 2
3 REPLIES 3
Message 2 of 4
Re: Fibre 900 - Asia ROG Rapture GT-AX11000 or Netgear NIGHTHAWK® TRI-BAND AX12 12-STREAM AX11000
@MarkInMK
The Asus ROG Rapture GT-AX11000 is a very capable router with superb reviews and will handle your 910 / 110 package with ease.
Please post back and confirm it does the job should you get one for others to learn from. 😉
PS: I have a friend using the same router with zero issues. 🙂
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 4
Great feedback and thanks!
Message 4 of 4
Hi please can you tell me if your friend successfully connected the BT Complete Wi-Fi Discs to the Asus router?
I just like the original poster have been toying with getting one of these two routers but leaning towards the asus one at the moment.
