Hi, I'm looking at getting bt broadband and TV, let's say I have it installed on the 19th JunewJune, roughly could I expect to receive the first bill?
Solved! Go to Solution.
Usually around 10 days after activation. It may be a little bit higher than normal as you'll be billed in arrears for what you've used up to the billing date and then in advance for the following month.
Hope this helps 👍
