Message 1 of 5
Galaxy A71 Answer machine
I have had a galaxy A71 for sometime now but have never been able to turn the answer machine on. I have recorded a message but the answer machine is never activated. Can anyone help?
4 REPLIES 4
Message 2 of 5
Re: Galaxy A71 Answer machine
Open the menu in the phone app (probably three vertical dots) and tap Calls then Call forwarding. Make sure the options are enabled.
Message 3 of 5
Dialling 15711 turns on diverts to voicemail (or any other number you set up to forward to, if you wanted to change it).
15710 turns it off if you change your mind.
Message 4 of 5
All sorted thank you
Message 5 of 5
All sorted now thank you.
