mazu
Message 1 of 16
HH5 alternative modems...
hey all
curious to know if anybody here is using a alternative modem to the HH5...
i find the HH5 to be unreliable and very flaky.. connection issues, wifi dropouts.. even browsing the modems web page causes it to go offline..
done a bit of research already and i came across this one..
TP-LINK TD-W9980 - N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
read some reviews and this http://www.ispreview.co.uk/index.php/2014/12/2015-update-broadband-router-options-uk-fttc-vdsl-isps....
they say that for the price its solid..
anybody got any other suggestions?
cheers
15 REPLIES 15
ray_dorset
Distinguished Guru
Message 2 of 16
Re: HH5 alternative modems...
Billion 8800 NL
If not, I'll try again 🙂
mazu
Message 3 of 16
yep saw this one too.. im actually a big billion fan but this one doesnt do 5ghz wireless and only has 1 gigabit ethernet port
i guess i can get a gigabitch switch but that just means i have to buy another piece of hardware...
ray_dorset
Distinguished Guru
Message 4 of 16
Or just plug it into the HH5.
Barry57
Expert
Message 5 of 16
I've become a big fan of using separate modem and router setup since the  ^Guru's^ recommended them as an option for my line.
eci/r or hg612 3b modem hooked upto a high end asus rt-ac68u seems a very popular combination on here.
Also I belive the ac68u  works with the mulit cast stuff for the tv box.
I have a unlocked eci/r  for the line info & old tomato linksys router & even that is light years ahead of the hh5 🙂
licquorice
Message 6 of 16
@mazu wrote:
hey all
Currently using the TP Link 9980, been rock solid.
Soyuz
Message 7 of 16
I have a TP-Link W9980 it is a nice bit of kit for the price, I have not opened it up yet but, I  believe it has a Lantiq chipset.
The BILLION Bipac 8800AXL is also a good choice if you want to spend some money.
Like has been said, using an openreach vdsl modem with the HH5 is a cheap alternative.
mazu
Message 8 of 16
@licquorice wrote:
@mazu wrote:
hey all
thanks... thats what i wanted to hear!
i am leaning towards giving this one a shot...
ray_dorset
Distinguished Guru
Message 9 of 16
Does it work with BT TV ?
mazu
Message 10 of 16
money isnt really a concern and id rather spend a bit extra and get a solid piece of hardware.
not really sure i understand this openreach vdsl modem setup.. but it sounds like theres 2 devices connected?
im liking the TP LINK 9980 so far...
