Hi all, I decided to try out my USB drive as a network drive today. When I plug it in to the USB port on the Home Hub 5 it appears as expected in the Hub manager. I can see it under devices, I can rename it, I can Safely Disconnect it etc.
However, it does not appear in Explorer under Network. I can navigate to it directly (I think) by going to \\192.168.1.254 in Run but the folder that opens is empty.
I have reattached it to my laptop and it works as expected.
Any ideas on how I can access the drive's contents on the network?
Thanks, Alex.
Have you tried using the forum search facility and look for hh5 and USB?
