I dialled 0800 587 5252 and it only gave me the option to set curfews, which I don't want to do - I want to disable the calls completely.
Solved! Go to Solution.
From your landline, dial 0800 587 5252
Select Option 1, then Option 5 to disable all messages.
Your request should be activated within 30 minutes.
