As the header says is there a way to tell if your exchange is congested
what makes you suspect your exchange is congested?
which exchange and cab are you on?
post router stats if possible
Exchange is bracklesham bay I'm not sure of cab would my adress help?
no don't post address
enter your phone number and post results leave exchange and cab but remove address https://www.dslchecker.bt.com/adsl/adslchecker.welcome#
Hi @mrmagicmart welcome to the community and thanks for posting, I've checked the BT wholesale congestion report and there are no congestion problems showing in the bracklesham bay exchange.
Are you experiencing slow broadband speeds during peak times?
That for some reason wont let me upload pictures says file too big but I now know it’s cab 9 and Bracklesham bay exchange if that helps
@NeilO Has checked your exchange and there are no known problems with congestion so need to look somewhere else for a solution
hub stats and btspeedtester results would be helpful
