Message 1 of 12
My cable does not fit the socket
Hello,
I have recently moved house and have confirmation that my broadband shall change over to my new address tomorrow (2nd April). However, the cable I have from the WiFi hub to the socket in the wall does not fit.
It is a BT socket, however, the entry port is much larger than my cable connector is. Will a new fitting come in the post tomorrow?
Lee Newton
11 REPLIES 11
Message 2 of 12
Re: My cable does not fit the socket
No, the lead should fit. Can you post a picture of both plug and socket.
Message 3 of 12
sounds like older style socket and you need to use a filter
Message 4 of 12
How would I get my hands on a filter? Is that something that BT provide?
Message 5 of 12
Message 6 of 12
Quicker from Amazon
Message 7 of 12
It should have come in the box that the hub was delivered in.
Message 8 of 12
Not sure they put filters in the box these days.
Message 9 of 12
OK Thank you very much for your help.
Message 10 of 12
Yes but you need to remove the link as it is against forum rules.
