Message 1 of 5
No Valid IP config
Hello, I know from looking around that this has been asked before but none of the offered fixes are working for me. Have scoured the web too but still no joy.
Situation: Desktop worked perfectly last week, all other devices untroubled and still connected, desktop now unable to connect via wifi or ethernet and I get a 'no valid IP' message.
I have tried (restarting between every attempted resolution): updating drivers,, uninstalling drivers, forgetting connections turning off powerline and going straight to the hub's wifi, replacing wifi card, flushing/renewing DNS, removing all instances of the desktop/mac address in hub's admin page address table, restarting the hub, setting static DNS in the windows TCP/IPv4 settings panel and everything else besides. The problem also exists in Ubuntu which is held on separate SSD in Desktop. So, any clues?
I understand the only option left may be to reset the hub? Massive pain as it means resetting P/W and settings to all devices. If anyone has a clue, do let me know.
Thanks.
J
4 REPLIES 4
Message 2 of 5
Re: No Valid IP config
Does seem odd that it is only one device with the problem, the one thing you don't appear to have tried is a direct Ethernet connection to the hub.
Not sure why you need to reset passwords and settings on all devices, just change the settings and password on the hub afterwards.
Message 3 of 5
Thanks Liquorice.
Not going to try direct ethernet connection - lazy and can't be bothered to unplug Dtop and move it all downstairs etc etc.
I don't re-use P/W and set my own SSID name and strong PW/security so will mean signing in again with each and every device but if there's nothing else for it............
Appreciate your time.
J
Message 4 of 5
@AndroidMancave wrote:
Thanks Liquorice.
J
Sorry, am I missing something here. Password and SSID are value x at the moment, you reset the hub and they become value y, all you need to do is change the hub back to value x and you are back where you started.
Message 5 of 5
Yes, right I am sure.
Nothing to lose. Thanks.
