Message 1 of 9
No signal
Hi.
I live in a 3 floor town house. I can get wifi signal on ground floor and first floor but none on second. I am hatd wired to my router with ps4 snatt tv and slovak tv so dont want to move router. Any suggestions please
8 REPLIES 8
Message 2 of 9
Re: No signal
Message 3 of 9
Re: No signal
You can buy wi-fi extenders on the BT Store, have a look Here
Message 4 of 9
Re: No signal
I had something like this sent to me. But it said i had to move router and connect one to router and a mains plug.and i wouldnt have ps4 etc hard wired?
Message 5 of 9
Re: No signal
Your router should have spare ports, most have four ports, but if they are all in use then you would have to add an Ethernet switch.
Is it a BT Home hub that you are using?
You do not need to move the router.
See https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Message 6 of 9
Re: No signal
Yes its a bt hub i am using.
Message 7 of 9
Re: No signal
That has four ports, so you should have at least one port spare.
See this example https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Message 8 of 9
Re: No signal
I was thinkingv of using whole home wifi?
Message 9 of 9
Re: No signal
It might be an idea to do a forum search for Whole Home Wifi.
