Message 1 of 4
Poor WIFI signal
We are finding that iplayer buffers a lot on wifi devices.
Have done a speed checker, and with a wire we are getting around 60mb download speed, but wirelessly when sat next to the router we only get around 20mb which seems a big drop. I assume this is not normal?
We have a BT Home Hub 4.
3 REPLIES 3
Message 2 of 4
Re: Poor WIFI signal
have you split the 2.4/5ghz networks as that may help  I would also select the channels manually probably using a wifi analyser on your mobile to find neighbours wifi channels and select a less congested channel
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
Message 3 of 4
Thank you for taking the time to reply. We do have devices on both 2.4 & 5ghz but both only give 20mb speed.
Message 4 of 4
have you split the networks?
