Message 21 of 53
Re: Premium Whole Home Wi-Fi SGAB204002 Early Adopter Release
Am I the only person have the Web Gui Crashing issue? Can't login via web browser or app after a few days and need to physically reboot the system (note internet connectivity still works)?
Message 22 of 53
@nchaundy
Try removing the 1 pack disc for a day and see if the issue goes away?
I had an issue that I still believe was related to a different manufacturing run of the discs as the replacements worked a lot better?
Message 23 of 53
Hi Sircoynie,
After completing the firmware update did you perform a factory reset of each individual disc as recommended?
Message 24 of 53
I had that also had to do a full reset
Message 25 of 53
Where does it recommend that?
Message 26 of 53
Ok thanks will give it a go..
The other thing I have done is remove all Ethernet conns from discs Apart from master..
Message 27 of 53
It doesn’t I just did it deleted app reset and re added
Message 28 of 53
Mine went crazy (See first few posts in this thread) when I updated. The hard reset solved my issues and I've been stable since the upgrade, not a single drop, and I'm getting full whack 370-380mbit throughout my house on virgin media...
Message 29 of 53
I see that this was fully released to the public on the 26th May and as I had enabled the early adopter feature I was already running this. My main disc rebooted on the morning of the 26th so can I assume it reloaded the firmware ? If bugs were found in the early adopter usage, would the version number change in the final release if these had been fixed ?
Message 30 of 53
Hi Marcel,
There is no change in the firmware version number now it has been released to all users, so your firmware won't have updated this week as you already had the latest version and you should still see SGAB204002 as your firmware version.
