profixit
Message 1 of 17
Re: Extending wifi signal of hh5 using a hh3
Hi All, The link above is dead. does anyone please have a step by step account of what needs to be done to link two hh4.
Many Thanks
16 REPLIES 16
Keith_Beddoe
Message 2 of 17
Reproduced from my website archive.
These instructions can also be used to link the HH5 and  HH4.
Important note:- Do not connect them together using the red WAN port on the HH4 or HH5. Only use the normal LAN ports.
Here's the how to connect two BT Home Hub 3s  to extend your wireless range and to create more Ethernet ports!
Note: There needs to be a physical connection between the two home hubs all of the time, for this to work.
HH3a (primary) recommended
Open a browser page and log in to the hub manager 192.168.1.254 or bthomehub.home
Change the default admin password
Click Settings, then Advanced Settings, then Continue to Advanced Settings
Click Wireless
(optional) Change the Wireless network/SSID to one of your choice ie. MyHub
Channel selection - select 1,6,11 or any channel with the least congestion (you'll need to use a wireless sniffer to see which is best)
(if device supports this) Wireless security - select WPA2
(optional) Wireless Key - change to anything you want but note that it:
  • is at least 10 characters long, but no more than 63
  • is a combination of numbers, upper-case letters (or ’CAPITALS’) and lower-case (or ’small’) letters
  • does contain punctuation, but no space.
  • is not a name or a dictionary word
  • does not repeat the same character one after another (e.g. aabbccdd00)
  • is not a commonly used key like ’abcd1234’, ’welcome1’, etc
  • is not the same as information given elsewhere on your Hub (e.g. your Hub Manager’s password, serial number or wireless network name/SSID)
Click apply
Click Home Network, then IP Address
(optional) Change the Lease time to 21 days and click apply
(optional) Click Port Forwarding, then UPnP and select off, click apply
HH3b (secondary)
Factory reset the HH3b by pressing and holding the reset button for about 15 seconds - NOT the restart
Make sure the wireless on the Laptop/PC is OFF
Connect the laptop/PC by Ethernet cable (NOT to the other hub). Open a browser. Ignore the not connected page.
Log in to the hub manager 192.168.1.254 or bthomehub.home
You'll be prompted to change the default admin password
Click Home Network, then IP Addresses. Change the IP Address to one not in use.
eg. 192.168.1.245 (NOT the default .254:smileywink:) or one of your choice (192.168.1.**), click apply (ignore any warnings)
As the page reloads SWITCH THE HUB OFF, LEAVE THE BROWSER OPEN
Once the hub has rebooted, clear the address in the URL and type 192.168.1.245 or the one you chose
Click Settings, type in your new admin password, then Advanced Settings, then Continue to Advanced Settings
Click Home Network, then IP Addresses, under DHCP Server, Enable select No and click apply
(ignore the warning)
Click Wireless
(optional) Change the Wireless network/SSID to one of your choice ie. MyHubSlave
Channel selection - select a different channel to the one selected on the primary hub - the next least congested channel. If you used channel 1, try 6 or 11.
(the wireless key will be removed)
Wireless Key - use the same key used on the primary
TURN OFF WPS, click apply
(ignore the waring)
Click Port Forwarding, then Firewall and select Disabled, click apply
Click UPnP and select off, click apply
Unplug the Laptop/PC, close the browser
Connect the HH3b to the HH3a using an Ethernet cable or powerline adapters (PLA's), switch the hub3b off and on again and you're done.
You have now extended the wireless range of your home network and increased the amount of Ethernet ports:smileyhappy:
Should you find that you don't get a connection, reboot the secondary to re-establish the hand shake to the primary hub.
Unplugging the HH3b will not affect your broadband connection.
HH3a (secondary)
Factory reset the HH3a by pressing and holding the reset button for about 15 seconds - NOT the restart
Make sure the wireless on the Laptop/PC is OFF, then connect the laptop/PC by Ethernet cable (NOT to the other hub). Open a browser. Ignore the not connected page.
eg. 192.168.1.245 (NOT the default .254) or one of your choice (192.168.1.**), click apply (ignore any warnings)
Close your browser this time, open it again and type in the chosen IP Address (.245 or .**)
Click Wireless
(if device supports this) Wireless security - select WPA2 (the wireless key will be removed)
Connect the HH3a (secondary) to the primary HH3a using an Ethernet cable or powerline adapters (PLA's), switch the secondary hub3a off and on again.
profixit
Message 3 of 17
Superb. You've put a smile on my face.
Legend.
Thanks Keith.
Best Regards.
Angelo
Keith_Beddoe
Message 4 of 17
That`s good.
Although I have taken my website offline, I can still copy local content from it, onto the forum, once I have checked that its still correct.
profixit
Message 5 of 17
Hi Keith and All,
Is it possible to link there or more hubs.
One Primary and two secondary's..?,both connected to the primary? Or one secondary connected to the other secondary?
Thanks in advance.
Angelo
licquorice
Message 6 of 17
Connect as many as you like. Either all connected to the master or daisy chain from slaves. Make sure you give any extra ones different IP addresses.
profixit
Message 7 of 17
Brilliant stuff, thanks for the speedy replies.
Kind Regards
profixit
Message 8 of 17
Quick question,hh4/5, would you still recommend using Type A's for primary hub.
Couldn't I use two Type B's, as I thought type B's are generally better.
Also can I slave, using the USB port
Thanks again
Angelo
licquorice
Message 9 of 17
Personally, I wouldn't use a HH at all.  Smiley Happy As far as I'm aware both types of hubs have their good and bad points. You can't slave using the USB port.
profixit
Message 10 of 17
licquorice what would you use?
HH are very cheap off ebay, local buys, a few pounds. Not The HH5, never sells for less than thirty.
