Message 1 of 14
Remote recording 465
Can I ask if the Bt Tv App has Channel  465 schedule  on paired devices to enable remote settings of recordings ?
13 REPLIES 13
Message 2 of 14
Re: Remote recording 465
@zulu17
Mine doesn't. It jumps from 463 to 466.
Message 3 of 14
thanks for confirming  @TimCurtis
Message 4 of 14
So it would  be good to have 465 listed in Bt Tv App guide so that remote  recording can be set for  HDR programming  such as yesterday s Premier league game.
Message 5 of 14
This is still an issue with channel 465 appearing to be missing from the BT TV app (Android)  guide thereby preventing the setting of remote recordings for the programming on this channel.
Message 6 of 14
This is the first I've heard of this - I had it added when the pro box launched. I didn't know it has disappeared again.
I'll get it sorted again tomorrow.
Message 7 of 14
I wouldn't be surprise that if #465 got re-added - that the remote record would set the recording on #433 due to the ID issue already reported.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 8 of 14
That issue should hopefully be resolved this week too @ozsat ... I'll chase tomorrow.
Message 9 of 14
@DarrenDev  I cannot be certain  but my suspicions is that the BT TV channel lists in their EPGs  and filter may have been  screwed up around the time of the Sky Max/Showcase launch which resulted in various channel renumbering and channel lists and the filter categories being incomplete.
Message 10 of 14
Any progress?
