Message 1 of 11
Reolink Argus 2 cameras
I have just changed my I ternet provider to BT and have got a Smart Hub 2. I am trying to connect my Reolink Argus 2 cameras up but every time they try to connect with the router it says connection to router failed. Has anyone got any ideas why
10 REPLIES 10
Message 2 of 11
Re: Reolink Argus 2 cameras
have you turned of smart setup
Turn Off smart setup
Message 3 of 11
I have turned smart set up of but its still not connecting to router
Message 4 of 11
Did you give your cameras static IP addresses with your previous provider, if so they may have been in a different subnet that the BT hub uses.
Message 5 of 11
Not that I know of.
How would I be able to check this please
Message 6 of 11
I doubt you have in that case.
You could try turning off the 5ghz wireless on the hub. Some devices sometimes get confused by the 2.4ghz and 5 GHz WiFi having the same SSID. You can turn it off in advanced wireless settings.
Message 7 of 11
I have already turned off the 5GHZ as it says they won't work with it.
Message 8 of 11
Is there a factory reset button on the camera, if so try a reset to clear out any previous config.
Message 9 of 11
I have don't but still can't get the to connect to router
Message 10 of 11
I have finally got them to work.
Might sound like a strange thing but I tried setting them up on another devise and the barcode on the back of the camera had to be entered manually rather than scanning it once I did it this way it worked don't know why or what the difference is from scanning the barcode or entering it manually but when I scanned it it wouldn't connect to router but when I entered it manually it worked.
Thank you to everyone who has offered advise
