Message 1 of 11
Returning equipment
I cancelled on the last day of my contract. Do I automatically get sent a return bag the day I cancel? As in they put the order in for it on that day so I recieve the bag a few days later?
Also, during my contract term my first hub devoloped a fault and I was sent a new one, they said I could keep the old one because I asked if I could use it as an access point. Do I have to return both hubs or only the one?
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
10 REPLIES 10
Message 2 of 11
Re: Returning equipment
If you have completed your minimum term you only need to return them if you want to. They are now yours to do with what you want.
Message 3 of 11
He did say if I kept it they would charge me £65, but he never mentioned that I had 2 hubs to return.
So you’re saying that if I’ve completed the contract (I cancelled it literally on the last day by moving to virgin) then I can keep the hub free of charge? And if this is the case then why did the BT chat support person say that if I keep it I will be charged £65? Thank you
Message 4 of 11
If you have completed the minimum term you can keep the hubs. I have no idea why the customer service rep said that, you would need to ask him/her.
Message 5 of 11
@Mustafa_Islam
If you wish to be kind to the environment and return it back to BT follow this link:  https://www.bt.com/returns
It was on the back of my newly delievered HH5.
Smiley Happy
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 6 of 11
Ok thanks, I returned one of the hubs with the return bag before I knew I could’ve kept it. I still have the other, I’ll just keep it and repurpose it as an access point, the virgin hub 3 hasn’t got great signal.
@CJT80 that link gives me error 500, but it’s all good now anyway, thank you
Message 7 of 11
@Mustafa_Islam
something with this forum... any link with any gaps at the end adds random characters to it!
Kind Regards
CJT80
Message 8 of 11
The link you should have posted is this one
https://bt.custhelp.com/app/answers/detail/a_id/53417
Message 9 of 11
@gg30340
I posted https://www.bt.com/returns
somehow it had a gap after it
Kind Regards
CJT80
Message 10 of 11
@CJT80 wrote:
@gg30340
That would be an error in copying and pasting the link. The forum does not add a space to links.
