jaminben
Message 11 of 28
Re: Reward card £150 now only £100
I have the same issue... registered on the 8th of Jan 2017 for BT Infinity and now only see the £100 reward card. I guess I'll register for it and hopefully get the correct amount but it's not a good start for a new customer.
vixen80
Message 12 of 28
I've had the same. when I signed up it was the 12th. the last day to claim the £150 reward. but my reward is saying £100. I've claimed the £100 and have sent them a query. hoping for the same result as Steve or I'll be even more annoyed. Nothing has gone right from the minute I signed up!!
Vpatel415
Message 13 of 28
Re: BT reward card wrong amount and no cheque for going through cable.co.uk
My amount should be £150 instead of £100 but I can see in my BT accounts only £100 I try to contact customer service still I didn't got any reply I don't know what to do
JohnC2
Moderator
Moderator
Message 14 of 28
Hi All, Sorry for the confusion over the amount showing for your BT Rewards card.
Please submit your claim and all claims are checked for the offer available at that time and the correct amount of Reward card arranged.
Cheers
John
Vpatel415
Message 15 of 28
So if items show me £100 in my accounts still it will send me £150 ?
Vpatel415
Message 16 of 28
Thanks for reply 🙂
Vpatel415
Message 17 of 28
I claimed it now and I m wating for reply from bt see what will happen:) I hope they check I bought infinity packages and they send £150 hope
Vpatel415
Message 18 of 28
I got msg in my mobile and its say bt here thanks for claiming your gbp 100 bt reward card we'll be sending it in the post shortly . So still I think they will send me wrong one ?
JohnC2
Moderator
Moderator
Message 19 of 28
Hi @Vpatel415 That was most likely a confirmation of your claim being received. The Reward team wont have replied to you that quick. You will receive an email from the Reward team when they have processed your claim and let us know then if there is still an issue.
Cheers
John
Vpatel415
Message 20 of 28
Thanks a lot for reply me johnC2
sure I will keep eye on my email and I will let you know if still I have any issue thanks .
And plz can you tell me how long it's roughly take them to process my claim .
