Message 1 of 15
Setup, cost etc of Digital Voice
We are due to get FTTP in the next few weeks and looking at options. I believe I can replace my landline with Digital Voice line. Some questions-
1- what does it cost?
2- Can i keep my current number?
3. Can i still use my analogue phones?
14 REPLIES 14
Message 2 of 15
Re: Setup, cost etc of Digital Voice
Are you an existing customer upgrading to FTTP or are you a new customer and if so who is current provider?
Anonymous
Not applicable
Message 3 of 15
There seems to be a lot of hysteria about Digital Voice, bear in mind that a corded phone connected to your old copper line will continue to work in the event of a power cut whereas  with DV your SH2 will turn off and so will your landline
Message 4 of 15
Not a current customer of BT. Currently with plusnet who don't do fttp
Message 5 of 15
I'm aware of the power issue with digital Voice but I have a mobile so not a major concern.  Main concern is I have multiple phones on extensions and a fax machine (I know!) that I need to consider as well.
Really mainly considering it for savings in cost (assuming there is no cost!) otherwise I probably would continue with the copper but not with my current provider as they won't do voice without BroadBand and they don't do fttp.
Anonymous
Not applicable
Message 6 of 15
A Fax machine??? For a moment there I almost thought you were being serious 😅
Message 7 of 15
I'm afraid I'm serious. It's one of the ways I communicate with my 88 year old deaf mother. She can text but for longer messages she faxes me. Working on facetime to sign but proving a challenge!
Message 8 of 15
If you get digital voice the the hub acts as dect base station and your phone socket no longer works-for calls so neither will your extensions.  I think that may also rule out your old fax machine
Message 9 of 15
Is it really dect? I assumed it would be over WiFi but that was just an assumption.
I thought I saw that there was a phone socket on the back of the router but not sure if I misread that (hence my question).
Message 10 of 15
Its DECT and you have to use the Smart Hub 2. It has a phone socket on the back, to plug in a normal phone.
If you want to use a different router, then it would be best to keep your copper landline connection.
I doubt very much that a fax machine would work over Digital Voice, owing to the way that calls are carried over the IP network. So you need to keep your copper landline.
