Message 1 of 5
Slow speed at peak times FTTC
Hoping to get some help. During peak times (17.30 - 00.00) my speeds are dropping considerably from 53mbps to a varying amount of 900kbps to 16mbps, my guaranteed is 35mbps. Also experiencing packet loss of up to 20% and ping of 157ms+. So far CS have been of no help and had 2 engineers who can’t find the problem. Can mods still help or has that stopped since the separation of BT and Open reach?
4 REPLIES 4
Message 2 of 5
Re: Slow speed at peak times FTTC
please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
can you run btspeedtester when download speed is ok and then again when you think poor and post results  must be done with ethernet connection   there is no speed guarantee on download speed as all speeds quoted by BT are connection speeds    https://www.speedtest.btwholesale.com/
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 5
Product name:
BT Hub 6A
Serial number:
+084319+NQ90775742
Firmware version:
SG4B1000E020
Firmware updated:
29-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
1 Days, 10 Hours 3 Minutes 6 Seconds
Data rate:
18.45 Mbps / 64.11 Mbps
Maximum data rate:
18452 / 65311
Noise margin:
5.8 dB / 3.2 dB
Line attenuation:
30.2 dB
Signal attenuation:
19.8 dB / 30.2 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5 GB Uploaded / 23 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-HT5T
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-HT5T-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
00:CB:51:A9:F4:61
Software variant:
Boot loader:
9.2.0
Message 4 of 5
Connection type:
Fibre Broadband (VDSL)
Downstream sync speed:
64.11 Mbps
Upstream sync speed:
18.45 Mbps
Network uptime:
1 Days, 10 Hours 4 Minutes
Broadband IP address:
86.151.236.150
Default gateway:
172.16.12.68
Primary DNS:
81.139.57.100
Secondary DNS:
81.139.56.100
System uptime:
3 Days, 18 Hours 43 Minutes
Serial number:
+084319+NQ90775742
Firmware version:
SG4B1000E020
Firmware updated:
29-Aug-2019
BT Wi-fi status:
Activ
Message 5 of 5
Spoiler
Ms
DOWNLOAD
52.82
Mbps
UPLOAD
16.77
this is by whole sale
this is what 2 others are saying
Your Internet speed is
18
Mbps
Latency
Unloaded
9 ms
Loaded
163 ms
Upload
Speed
15 Mbps
Client   Bremhill, GB   86.151.236.150   BT
Server(s) Bristol, GB  |  Guildford, GB  |  Slough, GB
