kleen
Message 1 of 15
Step by Step guide to configuring Unifi Security Gateway (USG) to work with BT YouView IPTV
How to configure a Ubiquiti Unifi Security Gateway with external BT Openreach ADSL modem to work with IP TV Services (BT TV / Youview)
BT TV and other IPTV services rely on a feature called “Multicast” to be able to stream live television over your broadband connection.  If you have the BT Smarthub, this is all configured out of the box to work without any configuration required.  If you have upgraded to a Unifi Security Gateway, there is about 15 minutes work necessary to configure it to correctly pass the “Multicast/IGMP” traffic from the Internet to your local network.
I spent several hours experimenting and piecing together previous articles, and I’m pleased to say I now have a foolproof setup.  Here is the step by step guide for you:
Note – this works reliably and consistently (No drop outs after a few minutes or IPC 6023 errors!)
My setup:
BT TV Youview box (manufactured by Humax) that is hard wired to my local area network
BT ADSL Infinity 2 Unlimited (I get approx. 76MB downstream speed on this)
BT Openreach ADSL Modem - ECI Telecom B Focus V-2Fub/r Rev B (Bought on eBay)
Unifi USG (3 Port Model) running firmware 4.4.12.5032482
Unifi CloudKey running firmware UCK.mtk7623.v0.8.2.c653dde.171107.2039
Unifi CloudKey Controller running firmware 5.6.22-10205
My external IP address is dynamically allocated by BT and changes
My internal LAN range is 192.168.1.0/24
My USG internal LAN IP address is 192.168.1.1
My Cloudkey Controller IP address is 192.168.1.6
I only have one “Site” in Unifi and it is the default one that is named “default”
*YOU WILL NEED TO SUBSTITUTE YOUR OWN ADDRESSES IN THE FILES AND STEPS BELOW FOR MY ONES*
Make a Note now:
My Unifi CloudKey IP address (eg 192.168.1.6/24) is:
My Unifi Security Gateway (USG) IP address  (eg 192.168.1.1/24) is:
My CIDR network address (eg 192.168.1.0/24) is:
What will you need:
To complete this you will need a PC that can connect to the Cloudkey Controller IP and the USG IP.  You will need to download and install PuTTY so you can open up a secure shell (SSH) connection (command line) to these boxes.  Putty can be downloaded for Windows PCs from: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Overview of process
There are three simple steps to get these services working through the USG:
  1. Create a configuration file on the Cloud Key Controller that tells the USG to run a “IGMP Proxy” service
  2. Instruct the Cloud Key Controller to “push” that configuration to the USG
  3. Create some firewall rules to allow the multicast / IGMP traffic through
Step One
Use notepad to create a file called config.gateway.json.  Enter the following text EXACTLY in to that file.  Take extreme care not to miss anything out or add anything:
"protocols": {
                "igmp-proxy": {
                        "interface": {
                                "eth0": {
                                        "alt-subnet": [
                                                "0.0.0.0/0"
                                        "role": "upstream",
                                        "threshold": "1"
                                "eth1": {
                                        "alt-subnet": [
                                                "192.168.1.0/25"
                                        "role": "downstream",
                                        "threshold": "1"
"interfaces": {
                "ethernet": {
                        "eth0": {
                                "address": [
                                        "10.255.255.255/32"
                                "mtu": "1508",
                                "duplex": "auto",
                                "firewall": {
                                        "in": {
                                                "name": "WAN_IN"
                                        "local": {
                                                "name": "WAN_LOCAL"
                                "pppoe": {
                                        "0": {
                                                "default-route": "auto",
                                                "firewall": {
                                                        "in": {
        "name": "WAN_IN"
                                                        "local": {
        "name": "WAN_LOCAL"
                                                "mtu": "1492",
                                                "name-server": "auto",
                                                "password": "bt",
                                                "user-id": "bthomehub@btbroadband.com"
                                "speed": "auto"
                        "eth1": {
                                "address": [
                                        "192.168.1.1/24"
                                "duplex": "auto",
                                "firewall": {
                                        "in": {
                                                "name": "LAN_IN"
                                        "local": {
                                                "name": "LAN_LOCAL"
                                        "out": {
                                                "name": "LAN_OUT"
                                "speed": "auto"
                        "eth2": {
                                "disable": "''",
                                "duplex": "auto",
                                "speed": "auto"
                "loopback": {
                        "lo": "''"
NOTE: Replace the IP address and subnet mask after the Alt-Subnet line with your NETWORK address.  In my case this is 192.168.1.0/24.  This is NOT the same as your gateway or router address and will end in 0
NOTE 2: Replace the IP address and subnet mask after the “ETH1” and “Address” lines with your USG LAN IP Address (in my case 192.168.1.1/24)
NOTE 3: Leave everything else EXACTLY as it’s presented above
Next open up putty and open a connection (ssh  / port 22) to your CLOUDKEY CONTROLLER IP address (in my case this is 192.168.1.6)
Accept the warning message about the SSH Thumprint, then enter the same credentials you use to login to the web interface.  In my case this is username: UBNT and my password.
Please visit https://www.cs.colostate.edu/helpdocs/vi.html and make sure you understand how to use the Unix “vi” text editor.  Just learn the basics for navigating, inserting text and existing saving the file (esc, colon w q!)
Once logged in type the following commands exactly – They ARE case sensitive:
cd /srv/unifi/data/sites/default
vi config.gateway.json
Go to your notepad containing the contents of the config.gateway.json and select all of the text (in Windows CTRL-A, CTRL-C)
Go back to your putty Window, where you have the vi editor open and do the following
Type a single letter i on the keyboard (this puts the editor in insert text mode)
Right click in the putty window and select “Paste”.  You will now see the contents of the file appear on screen
Press the following keys in exactly this order:
ESC : w q ! Return
Type ls – you should see a file in the directory called config.gateway.json
Type cat config.gateway.json – you should see the contents of the file exactly the same as in your Windows notepad version on the PC list appear on screen
Close the putty session.  Everything else now can be done via the GUI 😊
Step Two
We now need to “push” the configuration we have just created on the CloudKey Controller to the USG box.  This is really simple.
Open your web browser and open the CloudKey Controller page (in my case this is http://192.168.1.6
Click on “Unifi Controller – Manage your Device by UniFI Controller
Log in if required
Click on the fourth icon down on the left (the “Devices” icon)
Click on your Unifi Security Gateway 3P device
Under the “Properties” window that opens up, Click the “Config” tab
Click “Manage Device”
Click “Provision”
That’s it – this forces the CloudKey Controller to “push” that new configuration that has been created to the Unifi Security Gateway
Optional Step – verify that the USG has received the new config and started the “IGMP Proxy” by doing the following:
Using the same steps as in Step 1, open a putty session – but this time open one to the USG itself (in my case 192.168.1.1
Type:  ps ax | grep igmp
You should see a line that reads “/sbin/igmpproxy /etc/igmpproxy.conf”.  This shows that the IGMP proxy process is successfully running!
Step Three
Now it’s time to configure some firewall rules.  This can ALL be done via the GUI 😊
Log in if required
Click on the second  icon up from the bottom on the left (the “Settings” icon)
Click on the “Routing & Firewall” tab
Click on “Firewall” at the top of the screen
Click on “Groups” at the top of the screen
Click “+Create new Group”
In “Name” call the group “igmp group”
In address, add the following 5 addresses (use +Add to add each one separately)
234.0.0.0/8
224.0.0.0/4
109.159.247.0/24
239.0.0.0/8
233.0.0.0/8
Click Save
Now Click on “Rules (next to the Groups tab at the top of the screen)
Click on “WAN IN”
Click “Creat New Rule”.  Leave EVERYTHING as default except the following
Name: “Allow IGMP Group to LAN
Enabled: On
Rule Applied: Before predefined rules
Action: Accept
Protocol: All
Advanced VERY IMPORTANT check the boxes next to “New”, “Established”, “Invalid” and “Related”
IPsec: Don’t match on IPsec packets
Source: Leave as defaults
Destination: Check “Address/Port Group”
Address Group: Select the “igmp-group” address group
Click Save
Click on “WAN LOCAL”
Enabled: On
Action: Accept
Protocol: All
Click Save
Wait for your firewall rules to update – and test your BT TV.  It should be working fine 😊
14 REPLIES 14
kleen
Message 2 of 15
Re: Step by Step guide to configuring Unifi Security Gateway (USG) to work with BT YouView IPTV
UPDATE
In Step 3 above, there are only actually 2 firewall rules needed:
In address, add the following 2 addresses (use +Add to add each one separately)
224.0.0.0/4
109.159.247.0/24
rylo999
Message 3 of 15
Hi kleen
I've been using Unifi USG, Controller, unifi Toughswitch and a couple of APs for a while. I've now switched to BT Inifinity and where I previously just had an ethernet cable from the previous ISPs router/modem into the USG now this set-up doesn't work with the BT smart hub.
So by completing all of the items you have listed, I'm assuming my network should work OK without having to change anything with the APs / controller etc?
I've read some reviews which suggest getting rid of the smart hub for a different router/modem as well?
thanks
kleen
Message 4 of 15
I dumped the "smart" hub and bought myself a Huawei Openreach modem.  Readily available on ebay for anywhere between £10-£40.  This then acts as a pppoe modem / bridge to your actual router (the USG)
rylo999
Message 5 of 15
thanks for that. I think that will be the best option to be honest. Just followed the actions from your post and I've done something wrong so I cant get out via the USG now on my old internet connection (I've still got this service for another 2 months so I've got time to play with them to get a working solution)
Cheers
kleen
Message 6 of 15
Take a look at the article over at; https://help.ubnt.com/hc/en-us/articles/215458888-UniFi-How-to-further-customize-USG-configuration-w...
Shows you how to extract your entire config to a file.  Then you can compare and contrast with mine and adjust the bits you put in your json file as appropriate.  You dont need to put everything from your config in here - just the changes we are making that aren't available via a gui option currently..
Good luck
Kind regards
Nick
ajsadeh
Message 7 of 15
Just to say thank you for this great solution - I had looked at lots and lots of threads on this and none quite worked.
FYI - I am a Plusnet user and this worked for me just by changing the PPPoE login credentials to my Plusnet one, but everything else left the same..
kleen
Message 8 of 15
Glad it helped ajsadeh 😊
Richard_Hillary
Message 9 of 15
 Hi Chaps,
I've already posted this in the unifi forum and not had a reply...
Well.. I'm a combination of stumped and confused. I've had fully working PlusNet (BT) TV for around 18 months now until the last week. I can't for the life of me find why I can't get the TV back on. I've checked everything using the plusnet supplied router and the TV works fine.
I was using a very simplified version of the config detailed here : https://community.bt.com/t5/Home-setup-Wi-Fi-network/Step-by-Step-guide-to-configuring-Unifi-Securit... and I've tried the exact config as detailed in that guide.
From what I can see when you change to an IPTV change (comedy central etc) the bandwidth utilisation jumps to about 15mpbs (about correct) and you can the USG WAN IN port light blinking rapidly. The packets don;t seem to be passing the firewall even with my original rules and the rules defined in the guide.
any suggestions?
 My setup is:
PlusNet 80MBs Fibre
Vigor 130 -> USG3 -> USW-8
I've tried various firmware and controller firmware versions and the problem persists..
Thanks in advanced.
Keith_Beddoe
Message 10 of 15
Welcome to this user forum.
You need to post on the Plusnet forum. This is the BT Retail forum.
Plusnet forum - Index | Community Site
