Message 1 of 5
TP-Link TL-WR940N with infinity
There is a strong chance that I am missing an obvious step but I cannot connect my new TP Link router to the internet.
I have set the WAN connection to PPPoE and used broadbanduser@btbroadband.com with BT as the password.
When I try to connect it is saying it is disconnected.
If I try to follow the quick step up steps it is saying that the cable is disconnected.
Am I missing something?
The router is plugged into the Mastersocketc5. Do I need a modem also?
Very confused so any help would be gratefully received. Thank you
4 REPLIES 4
Message 2 of 5
Re: TP-Link TL-WR940N with infinity
It is bthomehub@btbroadband.com
Message 3 of 5
That device is just a router,  not a combined modem/router, you need a standalone modem as well.
Message 4 of 5
Ah okay, thanks. Any recommendations? Thanks
Message 5 of 5
There are not many choices of standalone modems, your choice is a used Openreach HG612 from ebay, a Draytek Vigor130 or a Netgear DM200. Various Zyxzel devices can also be used in bridge mode.
You might want to consider a combined VDSL modem/router instead.
