Solved! Go to Solution.
Try the usual fixes for the home hub, in this order.
factory reset the home hub.
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/443
Then separate and rename the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/447
As well as the info that Keith has posted, you should "forget" the wireless connection on your devices then re-start the device before trying to re-make the connection using the wireless passkey/password, not the admin password, that is on the hubs label.
@emmalouised710 wrote:
The factory reset worked, thank you.do I still need to do the other two steps??
Its best to disable smart setup, as that can cause problems.
Renaming the SSIDs is a good idea if you have any Apple devices.
Other than disabling smart setup, not really.
