Message 1 of 4
Why can't I access BT Wifi hot spots despite being a BT Broadband customer?
I've been a BT customer for over 20 years and have always had my BT through them. My package allows me to access BT wifi hotspots, but regardless of was username/email address and password, it won't let me use the hotspot.  Tries to sell me some, defeating the object of having a free one!
Please can someone point me in the right direction, it would be quite useful right now.
Many thanks in advance
3 REPLIES 3
Message 2 of 4
Re: Why can't I access BT Wifi hot spots despite being a BT Broadband customer?
If you have been a BT customer for over 20 years you should use the Primary email address and password that you were given when when you first signed up to BT.
See link
https://bt.custhelp.com/app/answers/detail/a_id/41199
If you are using a BTWifi hotspot you have to make sure that you are logging on as a BT Broadband customer.
See links
https://www.btwifi.co.uk/help/login-with-bt/help-broadband-customer.jsp
https://www.btwifi.co.uk/help/login-with-bt/connect-using-your-pc.jsp
If you are using a mobile device you are best to download the BTWifi App and use that to log on.
Message 3 of 4
Hi,
You can also check the link http://home.bt.com/tech-gadgets/phones-tablets/how-to-use-the-bt-wi-fi-app-11363896271683 to access wi-fi hotspot on your smartphone.
Message 4 of 4
Hi,
You can also check how to get connected to wi-fi hotspot through link http://home.bt.com/tech-gadgets/phones-tablets/how-to-use-the-bt-wi-fi-app-11363896271683.
