Message 1 of 4
can not log in to settings on BT Business hub 5.
Hello,
I have a BT business Hub 5 router and have changed the password to log in this goes fine, but when I enter the right password to enter the settings it tells me wrong password but I have entered the right password, have changed the password but this does not help.
Any help would be great.
Matthew
3 REPLIES 3
Message 2 of 4
Re: can not log in to settings on BT Business hub 5.
Factory reset the hub back to the default password and leave it at default, there is no need to change it.
Message 3 of 4
BT Business hubs have different firmware to residential. If a business user you should post in the business forums where you wil get more support. https://business.forums.bt.com/
Message 4 of 4
will reset the hub and let you know the outcome
Matthew
