Message 1 of 5
connecting a smart plug to BT Hub
Trying to connect smart plugs to BT Hub and it's not finding it, I tried splitting it into 2 bandwidths and connecting on 2.4ghz but still no luck. Any ideas?
4 REPLIES 4
Message 2 of 5
Re: connecting a smart plug to BT Hub
@tharari have you tried turning off the smart set up feature on your Hub as that may help?
Message 3 of 5
Thanks, unfortunately that didn't work 😞
Message 4 of 5
Try changing the SSID on the home hub, so that it does not have any non-alphanumeric characters in it, as many wireless devices do not like these. In other words no spaces, or dashes, keep it simple,
Try renaming the home hub SSID to something , like  bthub
Then rescan for wireless networks and try connecting the smart plug to the new SSID.
Message 5 of 5
How are you trying to connect the plugs? Can you try to associate them by pressing the WPS button on both devices? (Not certain if home hub has a wps button as don't use the hub)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
