Message 1 of 3
Parental Controls not working
We have the same issue. Works on Firefox and Windows PC but no protection when using Safari. Any ideas? Did you manage to fix it?
2 REPLIES 2
Message 2 of 3
Re: Parental Controls not working
Hi @GeddyButler,
Thank you for posting. I've moved your comments onto its own thread. When browsing in Safari do you have iCloud Private Relay enabled?
iCloud Private Relay will protect Safari traffic from being visible to anyone. This means that we can’t prevent access with Parental Controls.
You can find more information here - iCloud Private Relay
Thanks,
Paddy
Message 3 of 3
No. Private relay is not enabled. Parental Controls will successfully block social media and streaming but not adult content.
