BT Cloud has closed x
See our help page for further information.
Message 1 of 18
BT YouView Box deleting scheduled recordings
My BT YouView Box has developed a strange habit of deleting scheduled recordings.
I set the box to record a series. I can see it is set by the red R on the guide and I can see it is set to record in "Scheduled Recordings".
It records a few broadcasts, then fails to record any more of the series. If I go to "Scheduled Recordings" the program/series is no longer there, even though the program/series is definitely still being broadcast.
If I set the box to record the series again, the same thing happens - a few broadcasts are recorded, then it stops.
Anyone else seen this issue?
17 REPLIES 17
Message 2 of 18
Re: BT YouView Box deleting scheduled recordings
Have you noticed any pattern on this happening on particular channel or groups / types of channel?
Message 3 of 18
@grahamm1
Can you give an example of the programmes this is happening to.
Message 4 of 18
Specific examples really are needed to understand what may be happening. Ideally within the last 7 days as Guide schedule data is still available to view.
Message 5 of 18
These were set last night, but gone this afternoon when I checked again:
EastEnders (BBC1) (series)
Kirsty & Phil's Love It.... (Channel 4) (series)
Dogs Behaving...... (Channel 5) (series)
It always seems to be when we set the box to record a series. Can't say I have noticed it when we set a single program, but that might be a coincidence.
Message 6 of 18
Thanks for the examples @grahamm1
Are these SD channel recordings or the HD channels ?
Do you know if you are in a location  where you get a choice of region for your Freeview channels ?
Message 7 of 18
These are SD recordings.
I don't think we get a choice of locations.
It's not a new box by any means and it has always worked fine before. This is a new fault in the last couple of weeks.
Message 8 of 18
Mine is doing the same and has been for a week or so now.
I used to have 2 pages set up.
Now I have to set the recordings every day, which can be 5 or 6 to do.
This is across all channels, BBC, ITV, Quest, Blaze, DMAX etc., etc.
Some are one offs, but most are series recordings.
Message 9 of 18
Switched the box on yesterday evening and all the scheduled recordings I had set were gone. The whole "scheduled recordings" page was empty and nothing had been recorded. Put a few back in again and will see what happens tonight.
Message 10 of 18
My update is that scheduled series will record the first time, but then not be there for the next episode, next week.
However, one daily one I have been testing on BBC1 has been OK. Not sure what will happen over the weekend.
