Message 1 of 15
Failed recordings
So my BT pro box is setup for IP channels and the last few days my box is constantly showing failed recordings. Also even previously recorded shows which were fine are now showing as failed. I've restarted the box but it's still the same.
14 REPLIES 14
Message 2 of 15
Re: Failed recordings
Hi @jam2000, sorry that your recordings are failing.
Are they still showing as failed? If so would you try a hard reset and test to see if it records ok?
Cheers
John
Message 3 of 15
Yes still failing, I don't understand how older recordings which recorded ok are now showing as failed.
I wiped the box and started again, hopefully it won't happen again.
Message 4 of 15
Please keep us updated @jam2000 .
Cheers
David
Message 5 of 15
I have had this issue ever since switching to IP channels, happens multiple times which can be very frustrating.
Never had this issue when using an aerial. I did flag this when on the trial for IP channels but still doesn't seem to be fixed.
All the recordings become corrupt and can no longer be played.
Message 6 of 15
I'm suddenly having this issue, recordings I know were OK are now saying failed to record and my only option is delete? Frustrating
Message 7 of 15
I'll get a day or two of failed recordings - but it then corrects itself.
I don't check everyday so don't know if the box is stuck during those times.
But it seems to be a batch of all planned recordings within a time frame of many hours (maybe 2-3 days).
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 8 of 15
Hi @Tracynico64
which BT TV box is it the BT TV Box Pro or one of the older models .
when you say the recordings were previously OK  was this this because you were previously able to play them  ?
Message 9 of 15
Oh really I'll leave it a, day or two then see what happens I think I only noticed it yesterday
Message 10 of 15
Bt tv box pro. Various recordings were there ready to watch, not gone out of date now, all of them say failed to record?
