Message 1 of 8
Heart Radio
Hi I am unable to receive Heart Radio on the BT Tv radio channel 728.I have tried retuning all channels but still nothing.The Heart logo comes up but not connecting to the audio channel.I can receive most other radio stations.
7 REPLIES 7
Message 2 of 8
Re: Heart Radio
There's been a reshuffle on some of the Freeview channels and Heart may have moved. Try retuning your channels
Message 3 of 8
Re: Heart Radio
Hi @sulahaka
Heart and Capital radio Freeview transmissions have changed the multiplexes they are using.
This occured in November with a period of overlapping transmissions on the old and new  multiplexes before in December the old multiplex transmissions broadcast ceasing.
Its possible that you find further entries in  the guide  for the channels in either the 792 or 800 range.
Message 4 of 8
Re: Heart Radio
Looks like something has gone wrong with the switch as it doesn't work for me either after a retune. I wonder if the retune is working properly as the hidden channels are maintained. Maybe it's only looking for number changes & can't recognise a change of mux of the same channel? Although Capital works.
No extra channels in the 790s or 800s.
A maintenance reset may be worthwhile but I CBA!
Message 5 of 8
Re: Heart Radio
  • Strangely enough I have just tried it again. I selected channel 728, pressed play, then pause then play again and it worked??? Weird.As you say maybe a maintenance reset will work  too but like you CBA!! Thanks for your input.All the best.
Message 6 of 8
Re: Heart Radio
Bizarre, same here. But tune away & back again & it still doesn't work until you hit pause/play.
Message 7 of 8
Re: Heart Radio
Exactly, very weird.Glad it’s not just me.Thought I might have a poltergeist!!!
Message 8 of 8
Re: Heart Radio
@sulahaka
Youview report this is now fixed & seems to be the case on my Pro Box.
