Message 1 of 4
Remote not working after factory reset of BT TV Box
I undertook a factory reset of my BT TV Box and now I am stuck on the 'Start Set Up' page.  The box won't respond to my remote control so I can't press on start set up.
I have inserted new batteries and tried pairing the remote again by pressing the Home and 9 buttons together until the purple light flashed 3 times.  I have also tried the Home and 7 buttons together as this was suggested somewhere else.
Does anyone have any other suggestions?
3 REPLIES 3
Message 2 of 4
Re: Remote not working after factory reset of BT TV Box
If by any chance you have an old model remote or universal remote kicking around, the Pro Box also responds to the old Humax IR code set.
Otherwise pulling the plug for a while seems to resolve a few oddities.
Message 3 of 4
How did you sort this out in the end? I'm having the same issue now.
Message 4 of 4
