Message 1 of 3
Tv deals
Want to know about your tv deals
2 REPLIES 2
Message 2 of 3
Re: Tv deals
@AsherElethu24
There’s a lot to know, and it very much depends on what you are looking for.
Are you, or are you prepared to become, a BT or EE broadband customer? If not, then none of the deals are open to you.
If you are, though, then your best bet is to use the search terms ‘BT TV deals’ and ‘EE TV deals’ in Google, and follow the links given.
Any specific things you aren’t sure of after doing your basic research, come back and ask.
Message 3 of 3
Re: Tv deals
@AsherElethu24
If you dont want to become a BT or EE broadband customer than I would suggest looking at getting the Now service direct if you want a few extra pay channels.
If you do want to become a BT or EE broadband customer than there are loads of different TV packages to choice from depending on that you are looking for
