WatchdogTS
0
Accepted Solution
BTOpenzone-H what is the difference.
I am using this connection at the moment, BTOpenzone-H, how does it differ from FON, does it count as part of my monthly usage allowance, or does it operate the same as FON, free wifi on the go.
TIA.
Sage
imjolly
Re: BTOpenzone-H what is the difference.
just the same as BTFON and doesn't count towards your usage
Sage
john46
hi The H stands for Home openzone to show the difference with the bigger openzone sites
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
