on 04-03-2010 23h02
Since Tuesday morning i have found a few domains that i can no longer get, i get the page DNS Error / Page cannot be not found. I see there are other people on Twitter with similar issues on BT DNS.
Have been trying www.apronworld.co.uk which is fine on all my friends broadbands who are not on BT Broadband.
I am on BT Broadband, both in my office and at home, and neither can see the domains. I have spoken to many other people also on BT Broadband and they can no longer see the domains either. I have also tried getting the domains from NON BT ISPs, and all other broadband networks get them with no trouble, so it appears to be a BT DNS problem only. I have spoken to the webhost, who has checked all DNS settings which are fine, and i have checked on www.dnsstuff.com, and the tracert works fine also.
I have phoned BT twice in the last 2 days, but have heard nothing back so far.
Anyone else have similar issues?
on 04-03-2010 23h07
Yes your right, just tried the link and it fails on BT dns settings. Changed network dns settings on pc to google dns settings (8.8.8.8 alternate 8.8.4.4) and works ok.
on 04-03-2010 23h21
as above
on 05-03-2010 7h58 - last edited on 05-03-2010 8h17
well to fix those problems gfolow this guide for win7 or vista.
1. Click the Microsoft Vista Start logo in the bottom left corner of the screen
2. Click All Programs
3. Click Accessories
4. RIGHT-click on Command Prompt
5. Select Run As Administrator
6. In the command window type the following and then hit enter: ipconfig /flushdns
for xp
start
run
type cmd.exe hit enter
inall cases you will see the following confirmation;
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
this should remove all dns entries from the local table, then google for the address your looking for, click the link and you will be taken there, replace the favourits link in your pc,
the reason why this happened is becasue either the dns server has been compromised or (more likley atm) you went to a website that changed to a forced virus scan telling you about errors on your pc, that number counter was changing dns entries in your pc for common websites that have been replaced.
so flusshing the dns cache will clear the problem, now get some script blocker enabled for your browser and if your running vista or win7 switch uac on so you dont inadvertently try using a dodgy bank site before it gets shut down, theres no publicity becasue there no need to tell everyone that the sites are only available for about 30 seconds before there blocked by isp's hence the dns error's![]()
on 05-03-2010 9h14
Hi folks,
Thanks for replies, yep tried flushdns etc, nothing like that cures it.
Yes changed dns server to google works, so like i said it is only BT DNS servers that have an issue.
Currently on the phone with BT, they have given me 3 dns settings none of which work, so hopefully they will now try and solve it.
on 05-03-2010 9h20
its odd that your experiancing hte problem unless you setup a default dns server in eithre the pc or the hub,
personally i removed them and if i cant just run to the correct site i google it then go there and save it, it would appear the dns cache on my pc is quite large now but no matter if i need to i will flush it again
seriously dotn preset a default dns server, i removed them last year when they were all getting compromised through various vulnerabilitys in the executable code, since then i rarely get a re-direct to one of theose not quite kosher websites, on the odd occasion i cant get to one by typing its address i simply search for it and then once its in the local cache it never gets any more problems ![]()
on 05-03-2010 9h49
Hi
I run a small web hosting business and have been experiencing the same problem with my domains.
For instance
Resolve fine for myself to
77.240.2.194
87.237.58.161
However I am getting an increasing number of clients who cannot access these sites and get "Site not found" messages from their browser. A ping or tracert gives an "Unable to resolve target system name" message. Changing their DNS servers to Google's resolves the problem.
This affects BT and Virgin customers also, who I am informed use BT's DNS servers.
Not really sure what to do about this?
Ian
on 05-03-2010 11h14
Hi Ian,
Yes we have the same problems then, tracert does not work, ping does not work.
A few of the domains i cannot get are:
Also same with it only being BT and Virgin customers who do not seem to be able to get the sites.
I am phoning BT everyday, plus leaving comments in forums and twitter, hoping that BT will finally do something!
Dave
on 05-03-2010 11h21
Similarly, we run a small web server for our clients, and are experiencing DNS problems across a number of networks - most appear to be related to BT customers, but also some Virgin and Orange customers are effected.
We've seen problems with access to all web services over the past 48 hours. We spent most of yesterday working on efforts to minimise DNS outage by adding 3rd and 4th nameservers (outside of our own nameserver) to all our domains. This seems to have has a positive effect, allowing some clients and customers to access web services again.
The main issue we're having at the moment is delivery of emails. Some emails get through straight away, others are taking hours or days. Some don't get through at all.
Our server is hosted with Rapidswitch, and we've seen a number of people with similar circumstances having similar issues, over the social networks.
We've done many DNS lookup tests over the last 48 hours, and results show that there are major DNS inconsistencies across a lot of networks, not just BT. Unfortunately, no one is taking responsibility or even admitting that there's anything wrong.
If anyone knows of further solutions, they would be most appreciated.
Thanks,
Matt
on 05-03-2010 11h52
