on 16-03-2010 10h48
I used to use BT Wireless Connection Manager to manage my wireless connections. Now I notice its system tray icon is absent and it no longer appears under Start -> All Programs. Windows tells me it cannot configure my wireless connection. However, its Wireless Network Connection Properties box has no Wireless Networks tab, so I cannot reset the Use Windows option tickbox.
Is anyone able to advise on how to get around this, please?
Solved! Go to Solution.
on 16-03-2010 10h52
which version ov windows are you using?
on 16-03-2010 11h50
I'm on XP Home Edition SP2.
on 16-03-2010 12h15
on 16-03-2010 13h25
I'm OK as far as right-clicking Properties for my connection/adapter, but then see only the General and Advanced tabs. The Use Windows box is on the tab I don't get! It sounds as if re-installing the BT WCM may be necessary. Is that available as a download?
on 16-03-2010 14h14
you could try emailing the mods and see if they can point you to a download location for it but i think the only place its available is on the cd that came with the hub,
if it came with an adapter then try searching for it in the bt shop, on the product page there might be the utility your after, only thing listed for the v2 hub is the manual.
on 16-03-2010 15h12
Pursuing the 're-install BT WCM' idea, I have now discovered that I can restore its system tray icon by clicking on 'change/remove' in its record listed in the 'Add or remove programs' utility of Control panel. From this icon I can access the BT WCM.
This is weird and probably not entirely as it should be, but functions as a workaround.
Thanks for your help - I wouldn't have tried that without today's discussion!
on 22-03-2010 12h08
I had an update to the help desk a while ago and as part of the update it said that the BT WIRELESS CONNECTION MANAGER was no longer supported and that they now relied on Windows to do the connection. As part of the update they transferred the details from the BT connection Manager to Windows. However this caused a problem in that it did not get rid of the BT CONNECTION MANAGER resulting in a conflict between Windows and the BTWCM. I overcame this by removing the BTWCM and going into the Control Panel and selecting network connections then properties . select wireless networks and then select Use Windows to configure my wireless network. Under Preferred Network your Hub description should be listed. Click on this and accept and windows should then start your wireless connection automatically when you next switch on.
Hope this helps.
