on 29-10-2010 20h35
For the past week Homepage has not updated the BBC News headlines. They are always two days old. Further tonight the Search box does not work correctly, it returns the BT retail search page and not Google. Is anyone else having these problems?
on 29-10-2010 21h02
no problems here. been working fine. try flushing your browser's cache,
on 30-10-2010 18h49
Thanks for advice. Search problem corrected itself??? but News still three days old
on 30-10-2010 19h26
check under the options that autorefresh is set & not off, or try resetting it
on 30-10-2010 20h27
Once again, thanks for advice but cannot find an option fro autorefresh. I'm using XP and pressing refresh manually doesn't solve it either.
on 30-10-2010 20h30
log in to your yahoo home page & use the options menu there, my apologies for not being clearer before
on 30-10-2010 20h37
Perhaps I'm being very thick, but the only reference to options on the Homepage is 'Internet Options' under 'Tools' and I cannot find any reference to auto refresh there.
on 30-10-2010 21h22
hmm, you have nothing like this when you login to btyahoo ?
on 31-10-2010 19h39
Thanks again, I was being thick. Looked at this and it was set to autorefresh every hour. Set it to 15 minutes and no change. Set it back to one hour and got news from 24 hours ago.
