Newbie
wenimowrip
0
Lease requested
I keep getting disconneted from the Xbox. When i check the router logs i see.
Why is it doing this when i have my Xbox set to always use the same I.P.
17:22:53, 31 Dec.(26194.130000) Lease for IP 192.168.1.64 renewed by host Xbox 360 Lease duration: 30240 min
17:22:53, 31 Dec.(26194.080000) Lease requested
00:08:11, 01 Jan.(50512.280000) Lease for IP 192.168.1.64 renewed by host Xbox 360 Lease duration: 30240 min
00:08:11, 01 Jan.(50512.230000) Lease requested
Distinguished Guru
Keith_Beddoe
0
Re: Lease requested
[ Edited ]
You need to set you Xbox network properties to a STATIC IP address, outside of the DHCP range of the hub, then there will be no lease to renew.
I have not seen the Xbox network settings screen, however if you can set it to the following values, it should overcome the DHCP problem.
IP Address        192.168.1.50    You can use anything  from 192.168.1.30 to 192.168.1.60 if you prefer
Subnet Mask     255.255.255.0
Default Gateway 192.168.1.254
DNS server         192.168.1.254
There is no need to do anything on the home hub devices list.
Setting the home hub to always use the same address, does not stop the lease renewing, it just allocates the same address every time, thats all. So you lose connection while it is doing it.
If your post is for my attention, please include "Keith" (check spelling) in the body of your forum post, otherwise I may miss it, due to the large number of posts. Thanks.
