Sage
Keith_Beddoe
0
Re: Unable to access some sites
Can you do a manual install here http://www.java.com/en/download/help/windows_manual_download.xml
Have you tried using a different Internet Browser?
jezhodges
0
All web browsers load the page, but will not start the download.
jezhodges
0
Got it installed. Here are the results...
allansmith
Hey, I'm having the same issues today. Some pages aren't loading at all. Other I have to keep refreshing, time after time. And others are taking literally minutes to load. Never had a problem until today. I'm in Cumbria, where abouts are you at?
jezhodges
Glad to know someone else is having an issue. I'm in Ross-on-Wye in Herefordshire. I have found changing to Google's DNS servers at 8.8.8.8 have improved the situation, although Facebook still won't load.
allansmith
0
Its always a relief when your not on your own with problems like this. Takes out the factor of hardware/setup issues. I've found a lot of the blogs I usually visit aren't loading at all. Facebook isn't too bad here but Ebay is a nightmare. Takes ages to load, if at all, on most attempts. Hopefully they look into it and sort it.
Sage
Keith_Beddoe
0
Nothing wrong with the speeds, it seems to be a general problem at the moment.
allansmith
0
Well I'll keep faith that it will get sorted soon :smileyhappy:
jezhodges
0
According to the service status here: http://btbusiness.custhelp.com/app/service_status_consumer/
BT carried out maintenance on its network last night. Maybe something happened then.
allansmith
0
Oh yeah, 00:33. I bet they forgot to put that important wire back :smileywink:
