on 12-12-2010 22h11
according to my bt home hub
| Connection time | 2 days, 09:40:44 |
| Data Transmitted/Received (MB) | 84.7 / 47.2 |
ive downloaded around 5gb but only says 84mb ?
where are these readings taken from ?
on 12-12-2010 22h29
these figures are based on the connection time of 2hr+. The figures reset when the hub disconnects or is reset. Better using the usage monitor in my account on BT.com
on 12-12-2010 22h33
2hrs+ !!! I think you mean 2 days+ ![]()
on 12-12-2010 22h35
just as well someone is paying attention![]()
on 12-12-2010 22h36
staking wrote:according to my bt home hub
Hi.
As you can see, the hub usage figures are not particularly accurate sometimes - especially if reset (manually or otherwise), which may not actually alter the connection time.
As mentioned, best to use the online system (which is up to a day in arrears) - quick links via my shortcuts option 14d or 14e. May I ask how you are getting the 5GB usage figure ?
