gingermart
0
hub manager 2
Hello, just installed my new Hub v2 after having Hub v1.Problem is that I cannot access The hub manager! When I click on the hub manager it tells me
Sessions Number
No more than 100 sessions at a time are allowed. Please wait until open sessions expire
 How can I get past this to change settings in my Hub v2
thanks
harrybeadlebaum
0
Re: hub manager 2
[ Edited ]
Hi and welcome to the forum,
There are a lot of useful tips about homehubs here: http://www.jarviser.co.uk/jarviser/howto1.html
"In your web browser type in http://bthomehub.home and hit enter" I think that's the information you want!
gingermart
0
Re: hub manager 2
http://homehub.home is the page that I keep getting the message on "sessions number......." and jarviser.co.uk does not have the answer either!:smileysad:
Sage
imjolly
Re: hub manager 2
just wait 30min and try again or another 30min then try again.  you will get in ok
gingermart
0
Re: hub manager 2
ok thanks for that see you in 30 mins or 60 or 90...................!:smileyhappy:
Sage
imjolly
0
Re: hub manager 2
don't know why that happens but have had it and really annoying but just patience and you will access it
harrybeadlebaum
0
Re: hub manager 2
I'm so glad I didn't get a homehub...
Sage
imjolly
0
Re: hub manager 2
happy with my netgear where I can tweak snr and don't get the reset problem when accessing adsl stats
gingermart
0
Re: hub manager 2
well, two hours and twenty minutes later and it still won't let me change any settings in the hub manager!:smileymad:
Sage
imjolly
0
Re: hub manager 2
well it's either patience or restart the hub.  restarting the hub may drop your speed and profile if you have restarted a few times recently
