on 13-05-2012 20h59
For anyone interested in using the TP-Link TD-W8960N on Infinity, as a cheap replacement for the home hub 3, there is some helpful information at the end of this thread, from a couple of forum members.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
Solved! Go to Solution.
on 13-05-2012 21h00
on 16-05-2012 21h14
ok thanks for all your help Keith
Pat.
on 16-05-2012 21h18
You appear to have posted on the wrong thread. But it does not matter, my software script found it, as you had included my name.
Something to think about in the future, you can always contact one of the people at the end of that thread.
on
22-05-2012
11h47
- last edited on
23-05-2012
8h08
by
PaddyB
That is great I am considering getting the TL-WR1043ND and I might even consider putting DD-WRT on it. Configuration should be largely comparable to what you have described. Thanks.
One Question. Is it possible to retain FON that way? Or do I need ot get a router that already does FON (like the Fonera2 with DD-WRT already). Or could I just not give the key to hh3wifi to all my devices, but only distribute the key to the second router?That way the HH3 would only be used for FON/Openzone.
Is it best to chain the 2nd router by putting it to an ethernet port on the HH3, the LAN2 port on the openreach modem, or any other way?
Thanks for your help.
on 23-05-2012 2h20
on 23-05-2012 6h17
You will not be able to transmit the FON signal, as this is done using a custom configuration within the home hub.
You can still use other FON hotspots, provided you are opted in. You do not have to use a home hub to be part of BT FON, (soon to be called BT WiFI)
on 23-05-2012 22h01
Keith
May I ask a question, on the products home page it says this
Supporting the latest ADSL standards, the TD-W8960N provides higher performance (up to 24Mbps downstream)
My connection is around 74mbps!! (Infinity 2 ) or am i mixing up megabytes with megabits ?
Andy
on 23-05-2012 22h10
If you are using it on Infinity, you are not using the ADSL part of it, only the router.
Its the same as the HH3, which can be used on ADSL and Infinity.
You may like to also consider the TP-Link TL-WR1043ND, which has a faster wireless connection as mentioned in this thread.
The TP-Link TL-WR1043ND is simply listed as a general replacement for the HH3, as ADSL users also have problems with the HH3.
If you only have Infinity, then there are plenty of other choices as well.
on 23-05-2012 23h57
Keith
Yes thanks for that..of course its just the router (why didn't i think of that !!) many thanks for clearing that up for me though !
Andy
