on 10-03-2011 15h13
I'm unable to connect to an existing vpn connection since BT Infinity was installed a week ago.
Can anyone suggest a solution.
I've tried pinging the address of the vpn but it won't connect.
I'm running XP SP3 on an HP laptop.
Solved! Go to Solution.
on 11-03-2011 15h40
13-03-2011 18h34 - edited 13-03-2011 18h35
Have you tired 'clamping' the VPN port?
For the HH3 goto http://192.168.1.254/index.cgi?active_page_str=pag
on 14-03-2011 10h18
VPN was setup in Windows ( WAN Miniport - PPTP).
I have a HomeHub 2.0 via an OpenReach modem ( Huawei EchoLife HG612)
on 14-03-2011 10h20
I did manage to connect one time after disabling url auto complete for IE8 ( as suggested in another forum post)
on 17-03-2011 10h27
on 17-03-2011 10h42
Check your status for Web Address Help - http://preferences.webaddresshelp.bt.com/selfcare/
If it shows that you're enabled, make sure the blue dot is in disable, click save and try your VPN again....
on 17-03-2011 16h05
Uninstalled Webroot Internet Security - vpn now working ok.
Already have McAfee Internet Security installed so looks like a self inflicted problem !
I'll just stick to Webroot Spysweeper from now on as a back up to McAfee.
