The problem lies with the sender.
I would agree but the OP stated he was receiving the attachments on his iPhone without any problems which would tend to indicate that they are being sent out correctly.
Everything is a bit vague at the moment can you clarify the following.
Are the problem attachments being sent from just a small number of senders or from everyone sending?
What file format are the attachments, are they .PDF for example?
Are attachments of the same format received ok from other users?
What mail application is the sender using to send the problematic attachments?
Anyone within that organisation (I'm assuming going through the same server)
Word, pdf, meeting invitations, PPT
MS Outlook, however it is all of the senders from the two organisations, not an individual Outlook account. I checked with two of them, and they say that "message format" is set to "when sending messages in rich text format to internet recipients convert to HTML format"
It would appear to be a combination of the sender using a non standard method of attaching the files and btinternet email not handling it gracefully somehow, which seems totally weird as you are using a third party client to receive the mail rather than BT webmail.
Can you definitely confirm if the emails are sent to a Gmail address (say) and collected by the same client your end, they are received ok?
Scratch that, it has to be Outlook 365 your end not handling it correctly as your iPhone app is ok.
As an experiment, can you try a different mail client to Outlook 365 temporarily. Thunderbird or EmClient for example.
I'll try this tomorrow, thank you for your help. I have to attend a family event now
See messages 6 & 7 where he took Outlook 365 out of the equation and only used BTMail webmail to receive the attachment.
