on 07-04-2010 17h42
When my computer slows or nearly stops - I start Windows Task Manager and see that the process BTHelpbrowser.exe is taking 99%of my CPU and 44,095K of my memory ...WHY ????
I have tried deleting the process - but that doesn't seem to work - the only way is to re-boot ! AAARGHHH !
I can't find anywhere on the BT help website where I can post this question - so it's over to 'the community' to help..Please.
on 07-04-2010 18h57
The BT desktop help software is notoriously incompatible with some Windows, particularly Vista and Win7. Usually it's trying to install an update that does not exist.
My advice is to uninstall all BT software and use standard a browser (preferably Firefox as the BT software may have clobbered your Explorer) and if you are on Wifi use Windows itself to connect rather than BT onnection manager
See here to remove software, and also see here if you use wifi.
on 07-04-2010 20h48
on 07-04-2010 23h50
on 08-04-2010 8h59
on 12-04-2010 13h20 - last edited on 12-04-2010 13h23
Hi Guys
There have been a number of improvements made to our Desktop Help, for instance we now use the Windows OS wireless manager, and we also now use Internet Explorer as our browser with the option of a BT Yahoo toolbar. This does work with windows XP, Vista and Win7 32 bit version. Approximately 2 million people have Desk Top Help installed and it has helped fix a huge number of issues so I think it’s a great piece of kit and well worth an install.
@Evenly
What version of Desk Top Help do you have?
If you’re not quite sure, the best thing to do is remove what you have at the moment with the following instructions:
1. First make sure old Desktop Help is uninstalled (start All Programs->BT Broadband Desktop Help->Uninstall)…check add/remove programs too for any sign.
2. In task manager if you see the following – remove it:
a) BTHelpNotifier.exe
b) McciTrayApp.exe
c) McciServiceHost.exe
3. If you see McciCMService.exe please stop it in services (control Panel ->Administrative Tools->Services)
4. In registry delete the following hives (to start regedit do Start->Run->Regedit):
- HKEY_LOCAL_MACHINE\SOFTWARE\Motive
- HKEY_CURRENT_USER\Software\Motive
Restart the PC
You can then download the latest version of Desktop Help and install it from here
Let us know how you get on.
Thanks,
Stephanie
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
on 09-02-2011 20h48
Good post
Just thought I'd add that there are a Shed load of people on the web trying to find out exactly what the "McciCMService" entry in Services is.
Many seem to think it's possible malwere.
It might ease a lot of minds if this entry were also headed up with a reference to McciCMService as a quick Google search makes no mention of it being part of the old BTHelpDesk software.... hmm, maybe this post will correct that...... ![]()
on 18-02-2012 18h38
Hi
Is this still an issue!!!! I am running on a Acer 3004WLMi notebook using XP Home Edition with Service Pack 3. For a long time my system has fequently slowed right done, sometimes coming to a complete halt. It will frequently not boot up properly and will often not shut down because programs have stopped responding.. Using event viewer I notice that when it will not boot up it is because McciCmService.exe has not responded to a Start command. In addition when it wll not shut down the program which has stopped responding is sometimes (although not always) McciAsyncEventMgrWnd. All this sounds suspiciously like the problems in this blog and others on the net which date from 2009/2010. The advice from Moderator StephanieG at that time was to reload the BTDesktop Help software and there was an implication that only earlier versions of the software might have been a problem. I only reinstalled Net Protect from BT about one week ago (i.e. about 12th Feb 2012) following a total reformat of the C drive (about the fourth recently). So does anybody know if there are still ongoing issues with this Motive software which is still being issued as part of Bt Broadband Desktop Help.
Thank you
